This should be fun!
Old Nov 19, 2010 | 11:30 PM
12valvin's Avatar
This should be fun!
Ok so I bought a bone stock 90 4x4 5 speed and Im gonna tune the pump , 3200 spring, grind the fuel pin, timing bump, and bhaf and straight pipe.
Now the cool part is my buddies dad has a dyno I can use as many times as needed. I want to get a bone stock run and then do each mod with dyno runs in between too see just how much power each mod makes.
My question is what order should I do each mod?
Old Nov 20, 2010 | 08:13 AM
kensmachine's Avatar
air filter and straight pipe than pump and timing than turn pin than 3200 spring than grind pin than a after market pin,than a 4" exhust.
Old Nov 20, 2010 | 12:21 PM
Order doesn't really matter to tel you the truth. Do the hardest first and do the 3200 spring, Leave everything else alone until you get Gauges
Mattster
Jul 20, 2008 01:55 AM
red_neck1984
Feb 6, 2008 03:23 PM
tywebb3
Jun 23, 2006 11:30 PM
