shocks?
Old Apr 26, 2018 | 10:40 PM
Brian.B's Avatar
shocks?
hey guys whats the best shocks for a for a 1st gen.......
Old Apr 27, 2018 | 07:41 AM
It depends on what you consider or think a good ride is???
I like the stock, stiff, firm ride that gas shocks give (i have Rancho 5000's on mine. ) Guys here, because of Jim Lane's legwork are switching to NON gas charged , oil filled regular style shocks, which give a smoother ride according to their users.
They will have to chime in regarding name and part numbers.
I've heard Billsteins are a favorite, and are not cheap by any means
Old Apr 27, 2018 | 08:10 AM
nonrev's Avatar
Super Moderator
10 Year Member
I went with Jim's suggestion on the pro comp 3000 non gas charged but I also did parabolic 3 leaf front spring at the same time, definitely a smother ride although there is a trade off, at least on my truck smoother ride = more body roll, I've gotten use to it but with no sway bars I would not be comfortable hauling a camper, but for a daily driver the combination shocks, springs are a big improvement over stock IMHO
Old Apr 27, 2018 | 08:21 AM
I threw on a set of Pro Comp 3000 on my 12V Ramcharger.
I love the way it rides.
Old Apr 27, 2018 | 10:47 AM
cougar's Avatar
Just got some front shocks for mine. Not much of a selection up here. Monroe Magnum is it.
Old Apr 27, 2018 | 05:04 PM
rlyons's Avatar
I switched to the procomp 3000s and I love the ride. I do pull a fifthwheel and no problems. Rides like a dream compared to the gas shocks I had on it.
Old Apr 27, 2018 | 09:21 PM
PapeCAT's Avatar
I use pro comp 3000 shocks on my 1973 D200 Club Cab with 1993 Cummins powertrain along with a newly rebuilt front end, and it rides great.
Old Apr 29, 2018 | 08:58 AM
Brian.B's Avatar
thanks guys and is it the pro comp es 3000....
Old Apr 29, 2018 | 10:36 AM
nonrev's Avatar
Super Moderator
10 Year Member
Yes sir those are the ones...
Old Apr 29, 2018 | 02:48 PM
TJE's Avatar
TJE
How are these mounted on the front....the front shocks aren't supposed to have a loop on the bottom??��
Thanks
Old Apr 30, 2018 | 11:15 AM
rlyons's Avatar
Thanks
They come with numerous sleeves for mounting. There is a loop on the bottom but a sleeve that goes through the rubber that has the two mounting bolt holes in it.
Old Apr 30, 2018 | 11:59 AM
TJE's Avatar
TJE
Gotcha! Thanks! I need to get these on my truck!��
Old May 1, 2018 | 10:18 AM
Boatnik's Avatar
Shocks? Does our truck have shocks? If I ran over a nickle I believe I could tell if it was heads or tails. LOL
Old May 7, 2018 | 08:20 PM
Boatnik's Avatar
Laughter is the best medicine.
Seriously, I run Monroe Gas Magnums. I feel that because the suspension on the W350 Dually is so stiff I would be throwing away money running the more expensive brands. The last set went about 200,000 miles before I replaced them. The only suspension modification so far has been adding a couple leaves on the front to level the truck when empty and 5000 pound air bags on the rear to eliminate sag with a load.
Old May 8, 2018 | 07:10 PM
peckens's Avatar
I feel the same. I got Kyb in mine. Did a test drive before and without shocks before installing. Huge difference. I still have to replace the front but I will wait till I do the leaf springs.
