Shifter Woes : Automatic Tilt Column
Old Feb 9, 2006 | 06:30 PM
banzaitoyota's Avatar
Well to further add to my FRUSTRATION with Automobiles and NOT have it be MY FAULT:
I took the truck in to get 2 new rear tires 225/70R19.5, yep big truck tires. The shop gets them installed over lunch and I pay the bill $412.00 and go to leave. The Shifter has no Detents left in it, you can move the shifter from Drive to reverse and vice a versa by just flicking the lever.
I take it back and they stand around scratching their heads trying to figure it out. After an hour they decide I need to bring it back later so the can dissassemble the column and fix "the loose spring or clip" that dropped out due to "wear". ********! It worked when I pulled in and was broken when I picked it up.
I have located a used one, but its $100 and 75 miles away. Still unable to locate a good exploded parts view at the dealer. Any suggestions??
Old Feb 9, 2006 | 06:46 PM
The detent (AKA rooster comb) is in the transmission, not on the column. Drop the pan, you'll see what dropped off or broke.
Old Feb 9, 2006 | 07:42 PM
Thats not the kind of thing I wanted to hear
Old Feb 10, 2006 | 06:19 AM
And where would one procure a new "rooster comb"?
Old Feb 10, 2006 | 09:55 AM
lovemysan's Avatar
It my be due to wear but it was probably assisted ,to demise, by someone wrenching on it in a hurry. The shop should at least offer free labor for the repair.
Old Feb 10, 2006 | 11:00 AM
No doubt it was old, but when it worked going into the shop; I expect it to work coming out of the shop less than 1 hour later
Old Feb 10, 2006 | 02:40 PM
Hot Rod 4's Avatar
I had a problem similar to this when I bought my truck. I would be making a left turn and the lever would just move into reverse. I ended up curing it by adjusting the lever that connects the column to the lever on the tranny. Another possiblity is that the spring and ball keeps the rooster comb in place has came out. This happened to a friend of mines gas burner.
Old Feb 10, 2006 | 06:05 PM
This is most likely what happened.
Old Feb 10, 2006 | 06:08 PM
Does anyone know where I can view a diagram of this assembly, so I am not diving in blind?
Old Feb 10, 2006 | 06:14 PM
BC847's Avatar
1st Generation Admin
See step one and three ~
In my mess, the comb part had worked itself loose on the shaft. That slack allowed the ball to pop out of place. Peening around the comb's mount fixed it right up.
Hope this helps.
Old Feb 10, 2006 | 06:46 PM
Thanks! That makes it easier
TOM R
Sep 3, 2011 05:18 PM
BearKiller
Jun 14, 2011 10:05 PM
ScarecrowNJ
Feb 27, 2009 10:28 AM
tabing
Dec 29, 2007 06:12 PM
Bigone721
Apr 2, 2007 05:40 PM
