runs 6 seconds and dies
Old 05-25-2019, 05:00 PM
BSealey's Avatar
Hello all, newbe here, I'm Bob.
Looking for a little help.
I have a 93 D250 12v 1st gen, It will fire right up cold or hot, will run 6 seconds and tries to stall, just hit the pedal and it will catch back up, then 6 seconds, it will try to stall again, Hot or Cold, does it ALL Day Long.
When I idle it up to around 1500rpm or higher, it will run for 6 seconds and die down, will not stall, but dies way down, then will catch up on its own, and every 6 seconds will do the same thing ALL Day Long.
Bleed air out mutiple times, seems to have No air in system, truck has 150,000 miles.
Changed fuel filter twice, No water or alge in fuel that I can see.
I replace the FSS, No Change. Just need to figure out what to do next...
Thanks for any and ALL Help.
Bob
Old 06-05-2019, 09:16 AM
jrs_dodge_diesel's Avatar
Moved to the 1st gen forum
I am willing to bet you have an injection pump issue. Your 1st gen should have the Bosch VE rotary pump. From my limited knowledge on them (my expertise lies more with the 2nd gen Rams), they can be DIY serviced/rebuilt. I'm sure the 1st gen guys that know more on these pumps can give you some better insight.
Old 06-05-2019, 09:33 AM
maybe368's Avatar
You know it probably isn't it, but I once had a loose connection at the FSS that would randomly shutdown while going and when I would jam on the go pedal it would recontact and go again. Just something easy to check...Mark
Old 06-05-2019, 12:55 PM
j_martin's Avatar
Sounds like a governor issue in the IP to me.
Old 06-05-2019, 09:51 PM
edwinsmith's Avatar
Received 1,037 Likes on 762 Posts
Probably Jerry Brown.
Old 06-06-2019, 07:26 AM
Received 2,372 Likes on 1,568 Posts
Okay that is some funny stuff right there!
Old 06-14-2019, 02:39 PM
BSealey's Avatar
Posted a video of the problem, after I changed the LP.
GhettoVaquero
09-11-2010 03:28 PM
svtrich
08-03-2009 06:32 PM
syclone1452
02-16-2009 09:44 PM
fsted7
01-29-2007 09:49 AM
L.T.
10-16-2006 09:01 PM
Quick Reply: runs 6 seconds and dies
