Running Real Bad
The last couple of day the truck has been running weird.
As soon as i get on the pettle, and try and biuld a bit of boost the etgs go way out of control, and the turbos lag badly. I can only hit 25 maby 30 psi witch is half of what i was doing before and the etgs are at 1600+ ,and i didnt make any changes. Its blowing alot of back smoke, more then before, and maby abit of white smoke just before the black smoke. Before i could hit 50 pounds, and not even break 1250d. now it 25 - 30 pounds and 1600+. Any thoughts? Joel |
Check your intercooler boot's ?or search for a leak somewhere in the system .
doest it idle really rough?
check all the intercooler and between turbo boots. |
Sounds like a boost leak to me too.
It idles and start like a new cummins should, a boot leak would make me very happy, because its not somthing serious.
But im amazed thata simple leak could make such a difrence Thanks I will keep you posted Joel |
Originally Posted by daking
(Post 2168474)
It idles and start like a new cummins should.....
But im amazed that a simple leak could make such a difrence |
