running AIRDOG in cold weather
Old Dec 25, 2010 | 07:26 PM
JonathanFleguel's Avatar
i am thinking about running an airdog system amnd i live in a cold climate.
do i need to run a fuel heater of some sort if so what and how should i run it.
is there a supplier in canada or do i have to get it across the border. thanks.
Old Dec 26, 2010 | 12:29 AM
92smokin blacky's Avatar
I've wondered the same thing. Especially where its down on the frame rail in the cold air, snow, slush and whatever thrown at it. I asked Airdog themselves and they said as long as you run an additive when it gets cold or #1 then you shouldn't have a problem with them gelling up, but if they do just put some 911 in the tank and run the pump for a little bit then its not gelled anymore. They also said to get the smaller micron filter for colder climates though.
Old Dec 26, 2010 | 12:23 PM
Blueboy's Avatar
I live in upstate NY, temp -0 sometimes, never
had any problems. I use power service in winter.
Old Dec 26, 2010 | 12:24 PM
ok is there anybody who deals these units in canada. thanks
Old Dec 26, 2010 | 12:53 PM
ofcmarc's Avatar
I don't run an Airdog but I deal with gelling issues on a regular basis.
The airdog will probably force fuel through the filters without gelling longer than a stock LP will. I know that the cold weather up here hasn't gelled my filter this year since I put on a piston LP.
The smaller micron filter would be better for the fuel system components but it will plug and gell easier than a larger micron element.
Old Dec 27, 2010 | 01:20 PM
Midnite's Avatar
I run a FASS (similar to the Air Dog) in Alaska and it works just fine. I'm not in an area that gets as cold as Ofcmarc, but it has got down to about -30 F. here last winter.
You definitely don't need a fuel heater, and mounting the unit on the frame rail where it's a little more exposed to the elements presents no issues in my experience.
For Canadian vendors you might check with BD or PDR. Both are in southwestern BC.
Just curious though--why are you wanting to get an Air Dog? The stock lift pumps on the 1st gens are good ones. Are you at the point with your fuel mods that you've reached the limit of the stock lift pump?
Old Dec 27, 2010 | 03:18 PM
ofcmarc's Avatar
Give me a low pressure piston LP any day over a stock 1st gen diaphragm pump.
Old Dec 27, 2010 | 04:30 PM
Midnite's Avatar
Interesting--I'd never heard anything bad about them before. I didn't run my 1st gen long enough to get into any lift pump problems.
Old Dec 27, 2010 | 04:39 PM
ofcmarc's Avatar
Nothing horribly bad about them but I like the extra pressure that a piston pump makes to help push cold fuel through a filter........and a bad piston pump won't fill the crankcase full of fuel either......
joel
Jan 22, 2005 08:59 PM
OUTDOORSMAN
Dec 23, 2004 09:14 AM
wings
Nov 8, 2004 05:32 PM
bensdad_canada
20
Apr 1, 2004 02:08 PM
xj2extreme
18
Jan 23, 2003 07:34 PM
