Rotor out of balance.
I believe that I have found the source of my constant vibration.
I am going to turn the rotor 180* on the hub and see if it stops in the same place, hopefully it is just the cheap Chinese junk rotors from the auto parts.
I am looking for some place locally that can dynamically balance my hub separately and then the rotor as an assembly.
I know they balance the brakes on race cars this way, but just about everyone I have talked to hasn't a clue what I am talking about.
http://www.racingbrake.com/v/main/dynamic_balancing.asp
This rotor has to be off by several ounces.
The other side is not as bad, but it is still out of balance.
So what do you think?
Jim
Jim
I think you are way too detail orientated................
Seriously, I could see it for a race car, the wheel speeds are far higher, but it would take at least in my rough head calculations more than just a few ounces at the radius and wheel speeds of your truck. New rotors can't be much more expensive than balancing your old ones.
If you are serious, I had my local electric motor rebuilder balance a set of blower pulleys for my supercharger drive, I had to make the balancing mandrel to fit my pulleys, but they didn't charge me too awful much ( 25 bucks for the pair IIRC )
All of my "older" cars and trucks had balanced drums and rotors (as evidenced by a portion machined off) from the factory. YES it makes a difference, those rotors are HEAVY!
The balancing costs money, and when you are selling rotors for 20 bucks, they probably cut that proceedure out. Pity.
Yep, I definitely think you are on to something. Sounds like the right idea, to move the rotor on the hub 180 degrees to see if it will balance out better. The one possible problem I can see by doing that is that you might end up with some runout in the rotor requiring machining, then afterwards your balance might change. I think it's worth a try though.
I used to get Canadian-made Aimco rotors at AutoZone that weren't too expensive...no problems...finished right out of the box; just wipe 'em down with acetone and throw 'em on. Never had one shimmy.
One of the funny things about steel is an absolutely flat and true piece can be spun and usually is out of balance due to the density of the molecules in one area as a result of the rolling process. A brake rotor/drum is an even bigger challenge to keep balanced. Jim, when I was a kid my father would take his cars to a little garage in Scio, Ohio because that guy was the only one left in the area that balanced the tire on the car, thus balancing the entire rotating mass. It did produce the smoothest ride we could get at the time but it had one major drawback. Anytime you remove the wheel you need to mark the parts so you didn't lose the balance when you reassembled the assembly. Today, I would add a set of Centramatics or Balance Masters to the trucks resume'. They balance the entire rotating mass after about 22 mph. I've had mine now for a little over 5 years and still love them. I strongly recommend them.
http://centramatic.com/Home.aspx
http://www.balancemasters.com/
bansh-eman
Jun 17, 2010 07:15 PM
jlipskoc
Feb 21, 2007 12:13 PM
wallypedal
Jan 30, 2006 05:46 PM
Bobcat698
Sep 19, 2005 06:53 PM
