Rod knock?
A member from DTR posted this on here awhile back, found it in my searches, when I was getting ready to pull my pump. The FSM also has a pic somewhat like this. This view is the backside of the VE, and shows where each injector line MUST go.
When reconnecting my lines back onto the pumps threaded ports, I could easily see how someone could accidentally connect the wrong line onto the wrong port, but I was prepared cause I labeled each of my lines prior to disconnecting them from the pump.
Excessive load from over sized tires/wheels will put extra strain on power train components. Will make a small problem show it's ugly head much faster and cause lots of problems.
That being said, sounds like a bad injector, get that taken care of quick, a burnt piston isn't cheap...
If you have fuel their it is coming from somewhere else. Possible the injection line itself and its seal with the nozzle or it is possible the nozzle has threaded apart but that's quite uncommon. The return line may also show up as a leak their but again not very commonly.
Standing behind the tailgate, facing towards the front of the truck, so the view looking at the back side of the pump. Whoever drew this up, was correct, as I double checked it when I one by one removed my lines at the pump, I labeled my lines and the ports.
mknittle (05-07-2017)
For those who don't have a transparent tailgate/cab/firewall, the posted diagram will preserve its integrity if the back of the VE is viewed while looking at it standing by the drivers side front fender.
edwinsmith (05-07-2017)
Got them out. On the way to city diesel in Knoxville now. The number one was wet all the way up. The rest were dry as a bone. They came out very easy. Someone must have been in them before I bought the truck. NOW....IF a man wanted a little bigger injectors what would he buy. Right now I'm planing on just getting stock ones.
