Rocker panels for club cab
Afternoon gents... getting ready to attack some long overdue body work on the old piece and I cannot source rocker panels for 92 club cab ... gotta be in Canada as I'm not going to pay 27%more on exchange rate and shipping would cost both arm and leg...
Anyone have a Canadian source for our long rocker panels and cab corners or am I stuck with buying 3 or 4 regular rockers and cutting and splicing SD |
From the factory they are two pieces. One section is the same as a standard cab and the 18" (give or take) is an extension. Sadly there is not a source for a club cab. If you have rust that extends into both sections you have to buy at least three to fix. Or if you have access to steel locally its not hard to buy this gauge steel and bend it. If the rust extends into the sub-frame buying just the rocker skins wont complete it anyways without bending some spare sheet metal to complete.
Freight train...
Is that 3 regular rockers per side or 3 to fix both sides? Thanks for confirming my suspicions |
When I restored my truck I went to a local steel yard and made my own drops for the rocks. The back sides where gone. From there I use a hole saw and made space for the plugs. Sharmen makes good rockers and they're complete.
