Rocker Box With Oil Cap
Old Feb 8, 2006 | 10:37 PM
Stomp's Avatar
I am waiting to get an approval on them and then I will post them.
Stomp
Old Feb 9, 2006 | 02:17 AM
frostie's Avatar
I know where there are some industrial engines with the valve covers you want, I just dont think they would part with them.
Once the valve cover is in place, the filler neck will unscrew from the piece that screws into the front cover. I would take it apart and check the treads, see if something else will go in its place, if not cut off your filler neck short and weld a lidd on it.
Old Feb 9, 2006 | 05:15 PM
Stomp's Avatar
Here are a couple of pics of the 24 valve set up. There are a couple more in my readers gallery.
Stomp
Old Feb 10, 2006 | 03:04 AM
bgilbert's Avatar
Non-intercooled fuel lines hmmm... Jeremy how do you keep that 'breather' hose from flapping into the engine fan? Oil won't pump out there?
Old Feb 17, 2006 | 05:09 PM
bgilbert's Avatar
I also need an almost-flush cover to block off the oil filler tube on the timing cover.
Does anyone know the part numbers for these items??
Oil fill tube elimination cap Cummins part number 3903463. ~$5 from www.reliablegoods.com. I picked up a breather like Stomp posted and it has two part numbers on it for some reason. If one was to ask Cummins for one, they could try both part numbers. 24V breather Cummins part number 3944730 or 3944961- this was printed on, the first # was imprinted on.
Old Feb 19, 2006 | 05:05 PM
BC847's Avatar
1st Generation Admin
FWIW, I found this parts manual that shows the oil fill/rocker cover on page 115 with the description on 116.
The front cover plug is on page 28 , description 29.
http://www.cumminsfirepower.com/imag...s/6bfparts.pdf
Old Feb 20, 2006 | 01:29 AM
bgilbert's Avatar
OH MY!!! Where did you come across that? That's usually something you have to pay for, THANKS ALOT!!! I saved it. Just what we all could use. All the part numbers you'd ever need .
Old Feb 20, 2006 | 11:29 PM
BC847's Avatar
LOL! I was just looking around for some Stuff for hot-rodding, and came across this marine 208hp fire pump-set engine. It appears to be based on the same block we use. Water-jacket after-cooler (sea water). Neat adapter to convert to dual fuel filter (of sorts).
Here's the spec sheet for it: http://www.cumminsfirepower.com/imag.../6bta%20f1.pdf
And it's installation drawings: http://www.cumminsfirepower.com/imag...stallation.pdf
sawboywv1
Mar 26, 2008 03:29 AM
sawboywv1
Mar 10, 2008 01:31 PM
VFDFireman
Jan 5, 2008 06:47 PM
sterling
Oct 19, 2007 05:32 PM
ajpulley
Jan 16, 2006 04:21 PM
