>>> return line for regulator ???
At first, I intended to completely replace the old rusty steel fuel lines on the truck in question with GATES rubber, PLUS a third line to handle the regulator's return.
Truck in question:
https://www.dieseltruckresource.com/...p-t319084.html
I was going to use 3/8" for everything; it is the same price as 5/16 or 1/4 and I already have plenty, plus adaptor barbs.
Then I got to thinking, seeing as the draw-line is going to be a single 3/8" line, and the factory return is a tiny 1/4" line (actually a bit smaller, as the steel tube fits inside the 1/4" hose), why cannot I TEE the factory return into a single 3/8" return-line in the location where the factory return hose connects to the factory steel line, and let this single 3/8" hose carry both the injector-pump return and the regulator return back to the tank ??
Thus, I would eliminate the need to bulk-head the extra return-line into the tank.
Is there any danger that the regulator's return could over-pressurize the injector-pumps return and cause problems ??
My line of reasoning is that the lift-pump can draw no more fuel through a 3/8" line than another 3/8" line can carry.
Wisdom please.
Thanks.
Truck in question:
Wisdom please.
Thanks.
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
hellotbone
Feb 26, 2003 03:28 PM
