Replaced afc diaphragm and now have no power!
#76
Its a 30mm piston, details here - https://shop.dieseltuff.com/14psi-HV...nstall-Kit.htm
#77
Don't bother setting idle with a tach - injectors, timing advance, compression, converter fluid coupling etc make factory specs a mere guideline.
Warm the engine up by driving it, then turn the AC on and put it in drive.
Adjust the idle down to be barely above where the mirrors vibrate.
Grease the heck out of the slip yokes and check torque on the pinion nut while you’re at it.
Its a two step between mirror vibration and driveline clunk.
As far as the 47RH - a compushift mini is about $350 shipped.
Or you could use the factory 93 ECM to control OD, and put LU on a dash switch (should be about $345 cheaper :-)
