Repair leaking fuel pin.
Old 12-18-2017, 08:34 AM
  #31
~rf~'s Avatar
leaky vent on decel
You don't have to take the whole pump off, just the pump top.
I have a leak from the vent on deceleration. I think that's what it's called. Do I need to by the whole kit to repair this issue?
New to diesel and getting my head wrapped around the injector pump.
Old 12-18-2017, 09:53 AM
  #32
Received 2,379 Likes on 1,572 Posts
A complete gasket kit for that VE pump is about $20.
If you plan on keeping the truck for a while I would recommend to buy the complete kit, use what you need and save the rest.
Then if something else springs a leak, you have it on hand.
mknittle (12-18-2017)
Old 12-18-2017, 12:09 PM
  #33
~rf~'s Avatar
Thanks Oliver. I figured I would do just that. Is this repair to the vent an easy job?
Old 01-29-2018, 09:36 PM
  #34
~rf~'s Avatar
what part to replace for leaky vent
Ok. I opened the top of the injector to replace whatever part need to be replaced for the leaky vent. I also removed the vent assembly. I'm a bit confused. Is there something in the vent assembly that I'm not seeing? I'm not sure what part to replace to keep the vent from leaking. Thanks
Old 01-08-2023, 09:28 PM
  #35
Erbstock's Avatar
No start
Dang it ! Just spent all weekend trying this fix for leak at afc vent. Put everything back together, no start. I never referred back to the thread for 366 spring for re-install. Looks like I missed the part about backing fuel screw out before reinstalling!! So bummed right now. Had to call out of work tomorrow and will have to tear pump back down and see if I bent/broke Fulcrum lever.
Old 01-08-2023, 10:27 PM
  #36
edwinsmith's Avatar
Received 1,037 Likes on 762 Posts
I did the same thing when I installed the 366 spring in mine. I was able to find a used lever but had to pull the whole pump apart to install it along with a seal kit. Pump leaked then so I had to get a rebuilt pump. GOOD LUCK!
nothingbutdarts (01-09-2023)
Jim Lane
12-19-2017 09:55 AM
gaberichison
12-21-2014 12:21 PM
Cowboy_Customs
10-18-2011 01:46 AM
Redneck_King
08-10-2007 12:52 AM
bigragu
10-17-2005 04:07 PM
Quick Reply: Repair leaking fuel pin.
