Rebuild your front D60 4x4 brakes (General)
#46
I replaced the spindles because of bad grooves. I pressed in new races and bearings on hubs also. Installed spindle nuts and washer according to spec. with socket. I cant get snap ring on end of the axle shaft that holds locking hub assembly. I tried pulling out axle from center chunk. I took apart and reassembled axle nuts twice..Anyone have any ideas what to check.
#49
Are you sure that the bearing races seated correctly? It seems that that may cause the spindle to not enter completely. That or wrong part...Mark
#50
If you have a new outer seal on the stub shaft, it can be a little "springy" and hard to compress while you are installing the snap ring, but it sounds like you might have something more serious than that.
#53
FWIW, the races should be solidly seated to the stop. It makes a distinctly different sound.when seated, when using a hammer and drift to set them, but you said that you pressed them in...Mark
#54
The following 2 users liked this post by Fordzilla:
edwinsmith (02-26-2019),
maybe368 (02-26-2019)
