Rear pinion seal
Old Jan 16, 2013 | 05:57 PM
johnny08's Avatar
Rear pinion seal
My differntial has water in it.. Even after cleaning it up. Checked again and still milky gear oil. My vent is clean.. And now I noticed the pinon seal is leaking.
Looked for the part. And I see many differnt seals.. I have 3.53 gears and the auto OD trans.. It's a 250 rwd my brakes are the bigger heavy drums...
How can I find out what seal to buy? And would that be how water is getting in??
Old Jan 16, 2013 | 06:05 PM
Chrisreyn's Avatar
there should be a tag on the diff housing that will have numbers on it, take those to an axle shop and they should be able to set you up..
Old Jan 16, 2013 | 06:23 PM
johnny08's Avatar
No tag present. I guess I'll have to measure the diameters of the old seal.
Old Jan 16, 2013 | 08:08 PM
bendturbo's Avatar
Had the same thing happen to me on my W350, pinion seal leaked like a sieve. Took it in to have it repaired only to find that the bearing race had been slipping in the case. Ended up replacing the the entire rear axle assy. to a D80 from 2000 1-ton.
Old Jan 17, 2013 | 08:24 AM
johnny08's Avatar
Really..
I might just find another rear axel.
pwrtripls1
Jan 7, 2008 08:55 PM
NoSparkplugs
Sep 1, 2005 12:09 PM
sawboywv1
Dec 9, 2003 05:43 PM
sawboywv1
Aug 25, 2003 05:29 PM
