Rear Drum Brakes Adjustment Tip
When I recently replaced my rear brake shoes / wheel cylinders & hardware kits in my Dodge, I found it difficult to adjust the rear brakes properly.
In order to adjust the star wheel to the proper clearance, you need to "spin the drum" in the forwards direction while adjusting the wheel to where you hear the shoes just begin to touch the drum, as explained in Jim Lane's sticky about drum brake adjustment. What I found to be a problem with my adjustment was the obvious problems of dealing with a heavy duty truck.... shear weight of the tire / drum and pressure from the trac loc differential moving both wheels..... but I found a simple answer that will hopefully help anyone out there who is going to be working on their brakes. Since there is so much weight on that axle, I first removed the tires after the truck was jacked up and on stands, as Jim pointed out the safe way of working on our trucks, or any vehicle for that matter. I still found it difficult to "spin the drum" with all of the tension on the hub from the trac loc & the other drum spinning. I came up with the simple concept of removing all of the pressure on the drum by removing the outer axle bolts in the full floater hub and pulling the axle out about 1/8" off of the hub. This allowed me to "free spin" the drum while adjusting the star wheel. With the truck not running, I could hear the contact point of the drum hitting the new shoes. After reaching that point, I hopped back into the truck, hit the brakes a few times to re-seat the shoes, and went back to the adjustment process. The disconnected axle allowed me to easily spin the drum without needing to be gorilla strong to spin both axles and the diff @ the same time. After adjustment, I put the bolts back in and replaced the tires. In reality, you don't have to remove the tire, but since I was bleeding the brakes as well , it worked best for me. Once I drive around for a week or so, I'll readjust the rear shoes after the "break in" period has ended. Hope this helps someone out there to maximize their braking efficiency while not stressing themselves out while doing so. On a final note: Since I just filled my diff with new gear oil, some of the oil leaked out while the adjusting process took place, due to the axle being removed from the hub that 1/8" I found that if I worked quickly, I didn't create a big mess, otherwise you will have to clean up the gear oil spilled on your wheel afterwords. If no gear oil drips out, I would be suspicious that your differential is low on gear oil and you should check it while you are down there. One of the outer bearings was shot on this truck due to oil starvation by the previous owner. Good luck T. |
Good tip. I actually just got done adjusting mine about 2 hours ago. I keep this in the back of my head for next time.
That is the way I have been doing mine for years, except I leave the tires/wheels on.
It is very hard to get an accurate job when the axles are connected. :cool: |
How can the wheel/brakes spin easier if you pull the axle shaft out 1/8"? I'm pretty sure you would have to pull it out at least 1.5" or else the splines will still be together. you could just jack up both sides of the axle and leave the trans in neutral...
Originally Posted by schamran
(Post 2913808)
The bolts hold the axle to the hub, and with removal, the hub spins free of the axle. You don't even need to pull it out 1/8" but if you don't it scrapes the gasket material and could damage it preventing proper sealing when the bolts are reinstalled |
Originally Posted by NJTman
(Post 2913828)
Try it...
Factory should have been bolts. Someone could have changed to studs at some point in time.
1 Attachment(s)
Originally Posted by Gots_a_sol
(Post 2913907)
Or someone just put studs in it to replace the bolts. Like I said.
(Post 2913944)
Originally Posted by Bencie
(Post 2913953)
Whole lot easier to get the axle out when using bolts...whole lot easier to damage a stud when using studs( striking with hammer to loosen axle)
Originally Posted by maybe368
(Post 2913949)
I bought these drums new and they came studded...nobody else works on this truck...like I said is this not correct?...Mark
There is nothing wrong with studs in that application. Just another way to get to the end goal of holding the axle shaft to the hub. |
| All times are GMT -5. The time now is 02:05 AM. |
