Rear diff (carrier) question
Well, last week I was pulling a car trailer and car for about 3 hours. When I would make slow sharp turns at intersections you could really feel the rear end binding and popping. I pulled the diff, how do I get it apart and inspect it? How can I tell what type rear diff it is? I was told it is a locking type. There was not metal shavings in the gear oil, so maybe I am ok just to replace clutches.
When mine starts doing that, which it will after a hard pull, I get a bottle of anti-slip additive and put it in and it cures it. Mine has did that for 100,000 miles or more and I pull my trailer all over the country with no problems.
If you want to pull it, remove both axles, then remove diff cover. There are four bolts , two on eith side similar to a engine rod cap, pull caps and it will come out. However if you dont know how to set it up, go find someone that does or read a lot and buy a dial indicator. If your really brave you can try it but make sure you count the shims on either side and get em back in same order.
MR. GADGET
Jun 23, 2010 11:35 PM
banana
Dec 1, 2009 11:44 PM
estrada5.9
Feb 2, 2007 08:25 AM
Little-bit
Feb 23, 2006 12:51 PM
blacksheep10
Dec 15, 2004 06:24 AM
