rear axle spindle nut
Old Nov 18, 2010 | 06:36 PM
bradshaw106's Avatar
Im in the process of installing seals and brakes. I need to track down a socket for the nut that holds the whole works together.
I took the calipers and measured the nut and it came out to 2.5" but when I came inside and jumped on the net everything i read says 2 9/16"?? im starting to second guess my measurements.... did they ever use a 2.5" nut??
Old Nov 18, 2010 | 07:30 PM
oilcan64's Avatar
yes 2 9/16 is correct. there's only a 1/16th of an inch between what you measured and what it should be. i did my brakes in april...all the springs were a royal pain in the edit. good luck with it
Old Nov 18, 2010 | 10:00 PM
Richie O's Avatar
366 Spring Chicken
I'm so cheap I made my own socket.
Old Nov 18, 2010 | 10:03 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
im so cheap my daddy bought mine for me thanks dad!
Old Nov 19, 2010 | 04:39 PM
i went into the local napa, they had one on the shelf for 17 bucks... didnt think that was to bad
DieselDale
May 23, 2020 02:56 PM
v8440
Nov 24, 2005 12:02 AM
Mr. Jimmy
May 19, 2004 10:25 AM
vinny
Apr 28, 2004 04:54 PM
wildolman
Oct 21, 2003 11:03 AM
