Quick stud question.
Old Sep 30, 2011 | 09:06 AM
pwrtripls1's Avatar
I torqued my studs down to 145lbs. Started at 35 and worked up in 25lb increments till 125, then went in 5 lb increments.
My question is, I bottom tapped the block and installed the studs hand tight. Then dropped the head on and began tq'ing. Someone later told me I should have backed the studs out off bottom some before tq. Is this true? Will this cause me problems?
I used to just call hotroddiesels with these questions but am now staying away from their. So now its up to the good ole 12v'ers to give me insight.
Old Sep 30, 2011 | 09:17 AM
BILTIT's Avatar
Studs are always hand tight.
Old Sep 30, 2011 | 11:02 AM
92smokin blacky's Avatar
Yeah I put mine in hand tight when I installed my arps with my head on.
Old Sep 30, 2011 | 03:35 PM
BC847's Avatar
1st Generation Admin
More often than not, hand-tight or looser will turn in (tighten) a little as you torque things up.
u2slow
Sep 1, 2011 11:01 PM
goose2w1
Nov 18, 2008 01:43 PM
74dart
Jul 7, 2007 07:58 PM
cluckmaster
Aug 12, 2006 07:24 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
