Quick Question about Turbo's....
Old Oct 23, 2009 | 05:18 PM
rockfoot's Avatar
I have searched the threads and it brings up every thread with "tubo" anywhere in the thread... please forgive me... How do you identify the different turbos? I have a '91 and am under the impression that performance can be improved by going to a later(?) or earlier(?) turbo. I think mine is, like, a 21cm and I need a 16(?)cm... What years should I be looking for and is it an easy swap ie. no cutting and welding exhaust pipes??? Thanks in advance. To crossy's son... loved the IP advance video... thanks. Rockfoot
Old Oct 23, 2009 | 05:26 PM
NO_SPRK's Avatar
is your truck a early 91 or late 91. is your engine intercooled? non-ic engines have 18.5cm exhaust housings. and i just found out that stick or auto they are the same. intercooled engines have a 21 or 21.5cm exhaust housing. some people put 12cm or 16cm housings on. spools quicker but less overall power and more egts
Old Oct 23, 2009 | 06:26 PM
rockfoot's Avatar
It is a non-ic engine... Is the size stamped on the turbo anywhere? Rockfoot
Old Oct 23, 2009 | 06:47 PM
jimbo486's Avatar
yes, it is stamped on the backside of the exhaust housing just next to the flange. should be an 18.5cm housing. the only i/c motors that received the 21cm housing were the '92s. '91.5s and '93s had the 18.5cm housing. the reason they reverted back to 18.5 housing after '92 was from all the low power complaints.
Old Oct 23, 2009 | 08:22 PM
rockfoot's Avatar
http://dodgeram.org/tech/dsl/Facts/91specs.html
The above link is why I am a little confused.... Thanks again, Rockfoot
Old Oct 23, 2009 | 08:33 PM
jimbo486's Avatar
well i can see why you're confused. i've heard otherwise, but the only way to prove it, would be to use a small mirror to look at the back of your turbo for the stamped number. but regardless, if yours is non i/c '91, you have an 18.5.
Old Oct 23, 2009 | 09:57 PM
What they mean on dodgeram.org is the 91.5 INTERCOOLED trucks have the 21cm housing.
Your truck being non intercooled will have the 18.5cm housing. On the BACKSIDE of the exhaust housing UNDER the downpipe OFFSET towards the engine you will see the numbers stamped "18.5" or it'll say "21" ...your knees on the core support will hurt after a few minutes so look for it quick
All the Non i/c trucks we've had, had 18.5cm housings which aren't THAT bad....But a 12cm housing is much better , For your mostly stock truck. An HX35/12cm turbo off a 2nd gen cummins is a nice upgrade for spool up and a nice whistle , and a few more MM's on the compressor side as well. bolt on
jcmoyer2004
Sep 28, 2008 05:09 PM
quicksilvr
Jul 21, 2008 10:17 PM
Dan Marino
Apr 20, 2008 03:57 PM
the496rocket
Oct 12, 2007 06:56 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
