questions about Borgeson install
I just got a Borgeson steering shaft and I'm missing some of the instructions - yah I'm one of those guys who read 'em.<br>The instructions mention making a seat for the set screw as shown in Figure A - they didn't provide a "Figure A". The instructions also say to slide the u-joint over the splined shaft to the depth shown in Figure B - again I got no Figure B to refer to. <br>Thanks for the help, Chriswhohastohaveinstructions
Patron Saint of 1st gens
Re:questions about Borgeson install
Chris,<br><br>I have a somewhat detailed set of "HOW TO" for that... here is the link...<br><br>http://turbodieselregister.com/forum...threadid=74267<br><br>As for your specific questions the "seat' they are referring to is one you make... <br>Once you have the coupler slid onto the stub shaft fully (so the end of the shaft slightly protrudes), AND your steering wheel is centered, use a 1/8" or 1/16" drill bit, and go thru the allen key hole with it. <br>Then use the bit to make a slight mark on the stub shaft for reference.<br>Remove the coupler, take a dremel tool and carefully grind a small "flat land" on the stub shaft for the allen key to "seat" on. That way it's not sitting on a couple threads and possibly work loose. Use medium strength loctite to secure.<br>Make sure your 'rag joint' is snugged up too.<br>While you have things apart, after you've removed the old coupler and BEFORE you start on the new installation do this too....<br>Lay under the truck, look up to the bottom of the steering gear box mounting bracket that attaches to the frame...<br>Use a bright lite and look for signs of early cracking on the rounded/radius curves of the bracket for signs of cracks.<br>Also check the bolt hole areas closely too.<br>You'll see extremely faint sign of cracks often with bits of rusty stains if there are any.<br>If none, carry on with the install.<br><br>Bob.
Thanks for the instructions Bob. I'll check out the mounting plate again to see if I missed any cracks. I had a '78 PW that had problems with the steering box coming loose from the mounting plate.<br><br>Chris
rjm022
09-29-2007 01:59 PM
