Question on headliners
Old Mar 16, 2008 | 09:15 AM
bigragu's Avatar
Seems like after a rain, snow, fog, or any type of weather w/ some moisture causes my headliner to "spot", meaning only a couple areas droop down. It is weird, it seems that the spots only have the thin layer of the fabric come down. When I feel it, no wetness. After I start the truck up and drive with the heater on everything tightens back up on the headliner. What gives??
Old Mar 16, 2008 | 08:54 PM
sooty's Avatar
unmanageable
hit it with some hairspray
Old Mar 17, 2008 | 07:55 AM
andyr354's Avatar
The whole thing will drop soon. Mine was the same way.
Andy
Old Mar 17, 2008 | 12:54 PM
janb's Avatar
I replaced mine with fresh headliner material and some 3M spray adhesive ~ $20 for both.
carefully remove, (not breaking plastic trim OR breaking molded foam form)
Place upside down on dining room table (or plywood on saw horses...)
pull off old liner, scrub the degraded foam off the backing / molded form that holds the liner. (Use a very fine wire brush, the kind for scrubbing pots and pans)
Spray the form and the back of new headliner material with the 3M contact adhesive stuff for headliners (moisture resistant...) place material into form, starting for center and working out to avoid bubbles and wrinkles. (extra set of hands help here)
Re- install... I'm waiting till after the rainy season for that, currently 2" of water standing on floor board. (leaking in from somewhere... all 5 of my 1st gens have done this in 100"+/yr rainy climate
Old Mar 22, 2008 | 12:29 AM
bigragu's Avatar
Hairspray? You have done this yourself? What is the hairspray supposed to do?
Old Mar 22, 2008 | 12:34 AM
stackx2's Avatar
i just redid mine myself turned out perfect. if you want we can do yours when you come down for the bbq
Old Mar 22, 2008 | 12:36 AM
bigragu's Avatar
I might just ake you up on that. Still want to know about the effects of hairspray...
Old Mar 22, 2008 | 12:38 AM
stackx2's Avatar
cool. it cost me 30 $ to do it
Old Mar 23, 2008 | 09:55 AM
kendaliaguy's Avatar
I got tired of inevitable glue failure and found a better solution.
I ripped five strips of ash on the table saw 1/8 thick, found the correct length with a string to wedge front to back along the roof. then I sanded the strips thinner at each end(taper about 7 inches back) so they would bend nicely to conform to the roofline, and tucked them in place--no more sag! It is a bit tricky to get the right length, and do use ash, it bends very well--sand very thin on the the end that tucks in the back (above the rear window) about four inches in to make the steep bend in that spot. I think they look good, too.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
