A question for the alpha welders out there!
Old 03-08-2017, 02:05 PM
  #46
Received 2,392 Likes on 1,576 Posts
Well hopefully yours looks less oil soaked and grimy.
Old 03-08-2017, 02:29 PM
  #47
maybe368's Avatar
Yeah, it is a brand new redhead reman. You should see the whole truck, it is amazing that it hasn't fallen into a big pile of rust...Mark
Old 03-08-2017, 03:14 PM
  #48
mknittle's Avatar
Originally Posted by maybe368
So, I was walking down the street and I saw 1 of the hundreds of old Dodges. I assume that this is what I need...Mark
Here is what you are looking for. The drag link will be one piece though.
Attached Thumbnails A question for the alpha welders out there!-sb-1.jpg   A question for the alpha welders out there!-sb2.jpg
The following 2 users liked this post by mknittle:
maybe368 (03-08-2017), NJTman (03-11-2017)
Old 03-08-2017, 04:47 PM
  #49
maybe368's Avatar
Thanks Mark, that is the first time I have seen one, it should be easy to spot. There is a small town 25 miles away that I pass through on the way here. It has at least 3 giant wrecking yards full of old trucks. I am going to see how many that I can find...Mark
The following 2 users liked this post by maybe368:
mknittle (03-08-2017), NJTman (03-11-2017)
Old 03-08-2017, 05:30 PM
  #50
BHD
BHD's Avatar
Where did you source the 3 piece drag link?
Old 03-08-2017, 09:04 PM
  #51
mknittle's Avatar
the TREs are ton 1970s-80s Chevy one ton.
moog
https://www.summitracing.com/parts/mog-es2026r
https://www.summitracing.com/parts/m...FUxqfgod67oElg
sleeve came from here.
http://www.partsmike.com/index.php/p...tieroddraglink
It is 6". I would have rather had it a little longer but he had it already made up and a little cheaper.
All it is is DOM tubing faced off and tapped 78-18 right on one end and left on the other.
I did ream the holes in the arms a little to get the nuts on far enough for the cotter pins to go in.
BHD (03-09-2017), NJTman (03-11-2017)
Old 03-08-2017, 09:13 PM
  #52
maybe368's Avatar
Hey Mark, is that a heim joint at the pitman and drag link?...Mark
Old 03-08-2017, 09:26 PM
  #53
mknittle's Avatar
Hey Mark, is that a hime joint at the pitman and drag link?...Mark
No they are stock 1 ton Chevy tie rod ends with a longer drilled and taped DOM tube instead of the stock split sleeve. I just had to be different.
Old 03-08-2017, 09:36 PM
  #54
mknittle's Avatar
I just added links to post 51. or is that area 51?
Old 03-08-2017, 09:51 PM
  #55
maybe368's Avatar
I know that heim joints are used commonly in racing applications, is there any reason that they couldn't be used in this application?...Mark
Old 03-09-2017, 07:49 AM
  #56
mknittle's Avatar
I don't think they are DOT legal. Inless they had seal they would be susceptible to dirt and grit contamination and would likely cost about $75 each.
And the holes in the steering and pitchman arms can't be tapered.
Old 03-09-2017, 09:15 AM
  #57
bigragu's Avatar
Man you do nice installs, Mark! My mouth started to salivate over a set up like yours, but then reality set in, LOL!
mknittle (03-11-2017)
Old 03-09-2017, 09:21 AM
  #58
mknittle's Avatar
Thanks Augie.
Old 03-10-2017, 08:23 PM
  #59
maybe368's Avatar
Wish me luck
Well guys, I am going to go to Miguel Aliman tomorrow and search the three yards there and I plan on buying every one that I find. That is if I find any and they don't try to gouge the Gringo too bad. The good thing is that the exchange rate is still around 18 Pesos/dollar, not too bad. I'll report what I find in the afternoon. I'll be going back to Hermosillo next week, they have a lot more yards there. Chances are that I'll find them there. Thanks guys, gives me something to do...Mark
NJTman (03-11-2017)
Old 03-13-2017, 08:42 AM
  #60
mknittle's Avatar
Any luck Mark?
Quick Reply: A question for the alpha welders out there!
