Pyrometer Help
Old Nov 13, 2007 | 10:50 PM
6speedcowboy's Avatar
It has a post heat cycle for the first few minutes the engine is running. It warms the intake air to reduce white smoke from the engine when it is cold
Old Nov 13, 2007 | 11:57 PM
Firstgenfanatic's Avatar
Thanks! That makes a lot more sense as to why my volt gauge bounches back and forth as the pickup warms up. Is it normal for other gauges to fluxuate back and forth while this process is working? My newly installed Pyro gauge needle bounces up and down in conjuction to the voltmeter while this grid heater cycling is occuring.
Old Nov 14, 2007 | 09:17 PM
It draws quite a bit of power so your voltmeter will drop a bit. It will be worse if your alternator or batteries are getting tired. The bouncing you are noticing in your pyro guage may be caused by it not getting enough power when the grid heater comes on.
GOT BOOST?
May 28, 2007 06:17 PM
StevenAg03
26
Feb 12, 2007 03:55 PM
triton0708
Feb 11, 2006 04:39 PM
skchevota
Oct 14, 2005 10:55 PM
fordsmasher
Jul 1, 2004 07:01 PM
