pyro tap size
pyro tap size
what size drill and tap do you need for a autometer prob? I used the weld in bung the first time I installed it post turbo on the DP but now that im getting my new turbo im moving it upstream
Most I have seen are 1/8" NPT. Uses an "R" drill bit, most people use an 11/32", though. It is really close.
I use a 3/16"(i think) compression x 1/8" npt fitting to mount the probe.
Just don't over tighten the compression part. Never had a problem.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
06Cummins
May 23, 2006 04:20 PM
