Pump timing, POD's, and other thoughts...
Old Dec 22, 2006 | 10:12 AM
KAyers's Avatar
From: Springtown Texas, the land of MILFs and Honeys
I don't readily have any way to check my pump timing on my truck. I advanced it about 1/8 inch when I reinstalled the pump. With the POD's, my truck smokes a good amount of blue smoke. I'm told this is usually alleviated by more timing.
How far is too far?
What risks and benefits are there to advancing it more than 1/8 inch?
I don't have heat issues or anything, just want less blue smoke.
Regards,
Kevin
Old Dec 22, 2006 | 12:31 PM
dpuckett's Avatar
Unfortunately the only way to really tell where you're timed is to find true TDC and stick a gauge in it. I had mine timed (moved) to where I thought it was a good deal over stock. Got the pump rebuilt, bench timed, and it is way farther up the gear case than it was before. I have had others that were at 2.1 at the same place my curent pump is on this truck. Every engine and pump combo is a little different.
Now, if you want to bump it a little farther, and see what it sounds like, go ahead, If you get a rattle like an old, cold 6.2/6.9 (both used same fuel pump), or an older Mercedes, you know you've gone too far.
Daniel
Old Dec 22, 2006 | 12:35 PM
JD730's Avatar
The old POD haze, the only time mine doesn't haze is when is shut down.
The down side to advancing the timing is increased peak cylinder pressures and the heat from combustion stays in the cylinder longer and could lead to piston damage from excessive heat, even if the pyro is in the safe zone.
Old Dec 22, 2006 | 04:05 PM
POD's can use all the timing you can give 'em. Shove it over to the head!
Old Dec 22, 2006 | 04:57 PM
4RnrRick's Avatar
Whats a POD? (PS its not in the definition cheat sheet - neither is KSB)...HintHint....
Old Dec 22, 2006 | 05:01 PM
stillsmokin's Avatar
I'm with wanna on that one, put it to the head. I did and it burns the fuel better, the blue smoke is visible at temps below 65F and gets worse as the temp drops. I don't know which injector washers you have in there, but most of us are running 0.020" instead of the thick stock ones, that cuts the smoke as well. Your sig shows the 4 inch as a future mod, better get to it with the pods! Some cooler air will help you out a ton too, unless you like tons of diesel smoke without smoking the tires.
Old Dec 22, 2006 | 05:09 PM
loch's Avatar
POD=prince of darkness injector, its a slang term for a crudely modified injector. They do smoke and give you more hp.
Old Dec 22, 2006 | 07:26 PM
Unfortunately I don't have access to that.
Old Dec 23, 2006 | 04:49 AM
bigragu's Avatar
I've got a brand new, still in box, set of PODS from PDR and have been getting doubts about putting them in. I canstill get my money back...what do you all suggest I do?
Old Dec 23, 2006 | 05:33 AM
For a play truck, go for it unless in-town mileage is very important.
Old Dec 23, 2006 | 11:47 AM
Forrest Nearing's Avatar
crudely modified? they're an OEM injector... they may not be optimal for our piston dish, but they're not junk...
call me kinky, but I love the haze!
Old Dec 23, 2006 | 01:05 PM
loch's Avatar
uhm look into the way a high hp inj is made, they pump liquid with an abrasive through them to increase the hp rating, a edm is precisely cut on edm machine.
In terms of quality a pod is a stone knife compared to a edm. Now that being said, I never implied a pod wasnt a good injector, they do exactly what they were made to do, smoke and make hp, an edm just does the hp a lot better with lot less smoke.
Old Dec 23, 2006 | 04:06 PM
Micaiahfied's Avatar
let me finish the statement too if you don't mind loch... edms make more HP with a lot less smoke for a fair amount more money. pods are a way to get ditry HP for low bucks.
Old Dec 23, 2006 | 05:13 PM
gman07's Avatar
The POD's smoke because their spray angle is different than the stock injectors. They are actually a "stock" 190 hp injector on something (not sure what), according to Greenleaf's first post here: http://turbodieselregister.com/forum...d.php?t=172934
It's also mentioned that they have a 265 bar pop pressure (stock is 245 IIRC) which will retard timing if timing isn't added at the pump.
Old Dec 23, 2006 | 07:02 PM
the POD's aren't extrude honed... they are an OEM injector made for a different application...
there's nothing wrong w/ extrude honing... my DDP4's burn WAY cleaner than the 370's did (which is the 2nd gen equivalent to the POD's)
