Pump timing
Pump timing
Hey all,
With a buddy I replaced the injection pump and injectors. The key for the pump gear came out so we had to take off the cover and remove the pump gear. My injectors were down 900 psi and the new Cummins reman were 3800-4000.
I have 2 questions,
1. What would the effect of being one tooth off between the cam and pump?
2. What adapter, etc would be necessary to accurately read timing off the pump?
I got 16.35 MPG on the last tank running 72-78 MPH actual 77-82 actual and I'm thinking with new injectors, etc. my truck should do better. It is a 1993 ClubCab LE w/ 211Kmi and 3.54's stock, empty bed.
Thanks,
Brian
I have 2 questions,
Thanks,
Brian
I can't comment on the the effects of being one tooth off other than you would either retard or advance the timing by how much I don't know.
To check the timing you need to measure the plunger lift of the pump at #1 TDC, to do this you need an adaptor that screws into the center of the pump head (theres a bolt in the center you take out) and has a dial indicator to measure the plunger travel.
Is your truck auto or 5-speed? Running 80 mph with an auto 16-17 mpg is all I would expect out of any of my rigs, but its my trucks with my driving habits. 18-19 mpg is what I get with my 93 with a lockup converter.
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
