Pump ?'s
Old Apr 8, 2007 | 12:25 AM
Bubba29's Avatar
Pump ?'s
I was wondering on the performance gains I would see if I bumped my pump timing? Also what about the pins and govenor springs? Anybody know of prices and/or where I could get them? Thanks!
Old Apr 8, 2007 | 07:51 AM
You will get better top end power, lower EGT and boost, and slightly better fuel mileage from bumping the timing.
Old Smoky pin or one of the knockoffs like Bully Dog is worth about 25 HP. PM Old Smoky for more info on his pin.
Governor spring is the best $15 you can spend on your truck. It lets the engine wind up higher, which makes a bit more power. The big benefit is the much quicker throttle response, it makes it feel like a whole different truck. You can get the spring from your local Bosch pump shop, or Scheid Diesel will mail you one. The part # is in the tech facts.
Old Apr 8, 2007 | 11:37 PM
Bubba29's Avatar
Thanks for the reply. I'm going with it!
Old Apr 9, 2007 | 04:26 AM
ol red's Avatar
Ok toys are in
Ok my parts are in fuel pin an 3200 spring. Ok how hard is it to pull the pump off i have to put a seal in the back of the ve pump. The hyd head is leaking on back of pump. What do i need to look for when i pull the pump off and to be careful of thanks.
Old Apr 9, 2007 | 12:11 PM
A_port93's Avatar
I got my gov spring from Piers Diesel Research and they mailed it to me for 21$ total.
Old Apr 9, 2007 | 12:13 PM
A_port93's Avatar
http://dens-site.net/Dodge_CTD/Gover...ing/index.html that should cover the install.. I just had a little trouble with the throttle indexing or whatever its called and when i initially started the truck it would try to die with any throttle so just make sure that you follow the directions verbatim.
powerwagon440
May 25, 2003 02:31 PM
Puke
May 22, 2003 12:18 AM
amartinson
0
May 4, 2003 01:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
