Pump Questions
Up here in AK it gets cold. Real cold. As a result we run a lot of # 1 for long periods of time. Most service stations switch the fuel from #2 to #1 in early september and don't change back until end of march or april.
My question is this: Since the VE pump is lubed by fuel, would it benefit by having a greater fuel supply from the lift pump even though #1 isn't the greatest lube? |
If your just worried about lube id use an additive.
I always run additive anyways. In the winter, I double it up as well.
amsoil makes a great diesel additive i use it in my own truck
A high pressure and more volume pump might help some,but Not as much as a good fuel additive.
I wouldnt think it would help it out any. If there is not very much lubricity in the fuel, shoving more thru it doesnt change anything. Since you already run additives, I think you would be fine.
It was just a thought. Back when I had a garage I would run #2 Almost year round and not worry to much about fuel system lube. No garage now no choice but to run the #1. Additive is my friend!
If the stock diaphram pump wears out I'll probly put a piston pump conversion on. I hear that they work better and also help the VE run better as well. |
