Pulsing voltage fix.
Old Nov 7, 2011 | 10:35 AM
apwatson50's Avatar
So on my fummins I used a dodge, unknown source, voltage regulator. I actually grabbed it from a vehicle in the junk yard. Anyways the lights would pulse at night, quite annoying. Even after adding all sorts of ground wires, etc...
My fix, use a FORD external voltage regulator!
Using this diagram:
http://www.junkyardgenius.com/chargi...ges/ford01.gif
However obviously the dodge alternator does not have a stator, so I didn't use this terminal on the regulator.
I connected the field wire to the upper field terminal on the alternator. Then the lower field terminal I grounded to the body/regulator case/battery.
Started the truck, no pulsing voltage gauge, steady DVM readout initially at 14.2 volts, turned headlights on voltage dropped to 13.7 and held there steady.
FYI the ford regulator also came from the junk yard.
So that was my fix rather than the blue mopar regulator.
After I drive it for a few days I will update on how it works.
Old Nov 7, 2011 | 02:57 PM
GIT-R-DONE's Avatar
What year of vehicle and what kind of vehicle in specifics? Ford what ?
Old Nov 7, 2011 | 02:59 PM
alex211's Avatar
70s ford trucks use an external regulator.
On my buddies 77 f250 we swapped in a ford taurus 3G alternator, it is internally regulated and makes over 100 amps easy. Those alternators may be a good upgrade for externally regulated first gens. The only change we had to make was drill out one hole in the alternator for it to bolt on to the factory mounts.
Old Nov 7, 2011 | 05:17 PM
apwatson50's Avatar
Yeah it was just a 70's, might have been an early 80's ford truck I pulled the regulator out of.
As for the Taurus alternator, that would be interesting if the mounts were close to the cummins. I bet the hardest part would be an 8 rib pulley for it.
Old Nov 10, 2011 | 09:09 AM
apwatson50's Avatar
Well drove the truck last night, in the dark, and no more pulsing head lights!
So that is a good fix and I can use any parts store's regulator.
now to get a spare....
Old Nov 11, 2011 | 09:10 AM
apwatson50's Avatar
Originally Posted by Scout4bta
What you need to do to use the Dodge VR is:
Run a negative wire from the battery ground to the VR case.
Run a heavy gauge wire from the case of the alternator to the block or batt. This is not an option.
Make sure you have full battery voltage at the VR. Use a relay is needed.
Been there done that on my Scout.
I had all of that, well now that I think about it the power to the VR was just through the key switch, not a relay. So there probably was a slight voltage drop. That would make sense.
Hope this helps other people though!
Old Nov 12, 2011 | 08:30 AM
apwatson50's Avatar
well its too late to fix my truck with the mopar regulator as I already have the ford wired in. Which gets power directly from the battery, but still uses the same switched power wire through the key. I presume to "turn it on".
Old Nov 17, 2011 | 03:18 AM
50th state's Avatar
to scout4bta,
How do you set up the relay you talk about in your post. I have all the grounds but still no charge
imbodie
21
Jan 8, 2024 08:49 AM
Ikes91
Oct 25, 2023 09:05 AM
apwatson50
Jun 28, 2011 06:14 PM
92cummisw350le
Oct 16, 2007 10:47 PM
