Pulling the power steering pump........
Old 04-23-2017, 09:53 AM
shortround's Avatar
Location: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
to replace the vacuum pumps.
1990 W-250. Top bolt on the power steering bracket ain't a problem, but the bottom bolt is a real PITA. Universal joints, universal sockets, and swivel sockets don't work. Too much of an angle.
Any suggestions or special tool advice?
Shortround out
Old 04-23-2017, 12:52 PM
Received 1,637 Likes on 1,112 Posts
There's a few threads which describe the wrench you need
Harbow freight has some cheapo versions
Be very careful removing the ps pump, as there are a couple of mounting bolt spacers on the bolts that fall out and disappear very easily.
Makes it much easier if you remove the oil sending unit switch before anything else. It can be done without removal, but it's clear of it when removed
Attached Thumbnails Pulling the power steering pump........-wcs2022_productimage_primaryimage_400.jpg
Old 04-23-2017, 02:01 PM
juggernautt's Avatar
I used an extension with a wobble end. It allowed just enough socket angle to get on the bolt. It looks the same as a regular extension except the square corners where you attach the socket are rounded off.
Old 04-23-2017, 02:53 PM
gyman98's Avatar
A ratchet wrench works really well, I also agree on removing the oil pressure sender before you start. It's very easy to break
Old 04-23-2017, 03:11 PM
deere country's Avatar
With your truck being a 90 model you have the early style combo pump that uses a pair of vacuum pods which has 1 of the pods right in the way of that bottom bolt. With that taking the oil sending unit out doesn't gain any easier access.
I would leave the top bolt in and remove the hard to get lower one out first. Once you get it loosened you should be able to thread it out by hand.
The following 3 users liked this post by deere country:
mknittle (04-23-2017), NJTman (04-23-2017), thrashingcows (04-23-2017)
Old 04-23-2017, 03:24 PM
Learn something new every day.....
Old 04-23-2017, 11:28 PM
Received 1,331 Likes on 862 Posts
I was going to answer with info pertaining to the IC style system, then I saw it was a 1990, and it has been many years since I pulled the one off my 89 motor.....so decided to stay quiet.
Thanks Deere Country for the good info!
Old 04-24-2017, 03:48 AM
Jim Lane's Avatar
A manifold wrench takes the nuts off with very little blood or tissue loss.
Jim
Old 04-24-2017, 07:29 AM
shortround's Avatar
With a "wobble" extension and a swivel socket combined with a long breaker bar, we finally got that bottom bolt loose. Everything else was a piece of cake.
Now that it's off and cleaned up a bit, everything looks good, power steering wise. However in the interest of not having to do it again, I'm thinking of replacing the pump since it's original, the eccentric bearing, and any other seals in the unit. I was able to find 2 each new, not rebuilt, vacuum pumps at a decent price,so why not rework the whole unit while it's off. Thoughts? It would be one less thing to go south later.
Thanks for the info guy's. I really appreciate it.
Shortround out
gyman98 (04-24-2017)
Old 04-24-2017, 10:26 AM
MrFusion's Avatar
"Me no touch nothing Indy! I swear!"
Old 04-30-2017, 07:42 AM
Jim Lane's Avatar
Aaah,
Temple of Doom.....
tony99
04-09-2014 08:25 AM
mullercarl
Competition / Pulls / OffRoad
45
03-19-2007 10:10 AM
DodgeCowboy
08-28-2006 08:57 PM
Captain Dean
04-30-2006 11:01 AM
amartinson
0
05-04-2003 01:55 PM
Quick Reply: Pulling the power steering pump........
