power steering problem
Here's the deal, this winter my 93 had been sitting for a while so I went and started it up to let it run for a little while. While it was sitting there idleing it started spewing out power steering fluid. It was pushing past the cap on the pump. I shut it down and haven't done much with it since.
The other day I went out to start it up since it's gotten warmer. I filled the power steering fluid back up and turned the wheel left to right several times and still no power steering. What's the deal???
what were your temps like where you are? it's possible the powersteering fluid could have gelled in the lines/box and had nowhere else to go when attempting to pump the fluid.
i also have the same problem, but mine is spewing out white fluid, and i belive that means its getting air in the system? the thing is my truck has sat for a year and i never had problems when driving it around the block. but now its warm out like mid 40's or so. so could it be the tempature affecting it?
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
burlhall
May 9, 2005 08:05 PM
