power steering help
Old Dec 30, 2007 | 03:32 PM
boostedve's Avatar
power steering help
i have a 91 dodge and i have done almost everything.. in the morning when i first start up my truck if i try to take off right away i dont have power steering but if i let it warm up its okay but not good.. like it should be. and then after i get to were i have to go and shut it off it pushes the fluid out of the cap i have tryed a synthetic fluid and alos lucas powersteering fulid no luck. i have it off the truck now and dont see anything wrong withit but then again dont really no what to look for.. any help guys.
jr
Old Dec 30, 2007 | 09:31 PM
Jim5870's Avatar
is your fluid foamy?
foamy fluid could indicate a loose or damaged or deteriorated
suction line, air can be sucked into the suction side causing foaming
and loss of pressure.
Old Dec 31, 2007 | 02:10 PM
boostedve's Avatar
not while its running. and both lines are new. i thought the same thing but still the same thing after changeing the lines and its been a few days of driving so im sure all the air is out.
Old Jan 1, 2008 | 01:19 PM
C/PRD/'s Avatar
Mine did the very same thing. The seals were leaking in the steering box so I started looking for rebuild kits and ended up buying a used box off a 2x4 and changing out the arm on the shaft (not sure what it's called) and after I got all the air out it's fixed! So my conclusion is that in my case of a hot power steering pump puking fluid and never really working properly it was the steering box. Hope this helps.
Old Jan 1, 2008 | 01:45 PM
jjdiesel1990's Avatar
Yeah my steering box leaks like a faucet in warm weather, but when it gets cold it seals up rather nicely and doesn't leak. When the weather first starts to change from hot to cold or cold to hot though, and the seals in the box expand/contract, air always gets in and makes the fluid foam and overflow and very hard to turn at first.
tony99
Apr 9, 2014 08:25 AM
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
RAK GUY
Apr 5, 2003 10:28 PM
Garz
Nov 17, 2002 02:02 PM
