please read everyone!!!!!! need advice
Old Feb 5, 2011 | 10:43 AM
  #31
maybe368's Avatar
Originally Posted by xxking9
Ok everyone i have just called my friend at the shop and he confirmed that i do have a CAV pump. and that i would need to find a bosh VE pump and have someone switch the spring and turn the pump up, with also changing the injector tips, would give me anywhere from 280hp-320hp. now the question is where do i get this Bosh Ve pump how much do they usually cost? also where do i get the spring and how much does they usually cost? any info will help thanks
My rebuilt one cost around 600, but that was with a core. Mark
Old Feb 5, 2011 | 10:55 AM
  #32
xxking9's Avatar
Dang! Where did u get it from. And where do u get them from does anyone have. One I can buy used?
Old Feb 5, 2011 | 11:00 AM
  #33
Onemoparnut's Avatar
If you are going to change the pump over I would go to a p pump. Unless the CAV pump and the ve interchange easily. If you have to go through all the trouble of changing all the injector lines and the timing cover anyway I would go to a p pump.
Old Feb 5, 2011 | 11:04 AM
  #34
xxking9's Avatar
I don't think I have to change the timing cover. Or any of the injection lines the man at the cummins place said just find a ve pump change the injectors and ill be good. How much better is the one u are talking about
Old Feb 5, 2011 | 11:05 AM
  #35
maybe368's Avatar
Here is one place. They are not cheap.At this price, you may want to live with 22 knots. You may be able to sell the one you have or maybe they may want yours and give you core credit on it...Mark
Old Feb 5, 2011 | 11:11 AM
  #36
G1625S's Avatar
The CAV appears to use the same mount as the VE.
For a marine application, I would invest in a fresh pump. If a truck quits, you can walk home. If a boat quits, well....
Old Feb 5, 2011 | 11:15 AM
  #37
maybe368's Avatar
Can one turn up a cav pump? I have no idea. Here is another place, with 800 dollar core charge...Mark
Old Feb 5, 2011 | 11:20 AM
  #38
maybe368's Avatar
Google answered my own question, Here is a site that talks about juicing many different pumps, including the ve and cav...Mark
Old Feb 5, 2011 | 11:23 AM
  #39
maybe368's Avatar
Juicing a lucas cav pump Here ...Mark
Old Feb 5, 2011 | 11:34 AM
  #40
gadget.35-06's Avatar
You may also want to ask yourself: "am I getting propeller slippage?" And is your drive a straight inboard, a v-drive or a sterndrive? Is there a reduction gear in the powertrain and if so, what is the ratio and how does that figure in RPMs at the prop?
There is more to a propeller than just diameter, pitch and number of blades. Do you use a cupped prop(one that has a visible, raised trailing edge)? They say the "rule of thumb" is to replace an uncupped prop with a cupped one you deduct about 2" in pitch. This in effect gives you the same propshaft RPM at a given forward speed of the vessel. Though I have seen 'em cavitate in reverse much above idle.
Was this a repower, after removal of a gas engine? The extra torque of a diesel often benefits a prop with greater disc area. This, if you have never read about it, is the ratio of blade area in relation to a solid disc of the same diameter. Ratios approaching(and occasionally exceeding) 100% are often achieved with five-bladed propellers(and on rare occasions, four-bladed). Some of the technical articles in magazines such as Boating can make for some interesting reading if you have the time!
Bad Ramer Jamer
142
Aug 18, 2018 04:24 AM
turfguy
Aug 10, 2010 11:49 AM
djbigblcstrkr
Feb 7, 2009 08:16 AM
canadiandiesel
14
Feb 3, 2008 12:36 PM
BIG ED
14
Oct 21, 2003 08:27 AM
