piston pump question
Old Sep 28, 2007 | 10:49 PM
1stgen's Avatar
Hey guys, my supply pump gave it up on my way home yesterday and i was thinking of going with a piston pump for a replacement. Here's my question: While searching ebay I found a place listing one with cummins part #3936318.
The description says it will fit B series 4 cyl and C series. Will this pump work on my 91.5 because he has 9 brand new ones at a really low "buy it now"price. Any help would be greatly appreciated.
Old Sep 29, 2007 | 04:23 AM
marksmith's Avatar
Nope.
The part number found in the sticky is the low pressure piston pump. You put that one on there and your likely to blow the front seal of the VE and fill the crank w/diesel.
Old Sep 29, 2007 | 07:37 AM
1stgen's Avatar
Thanks. Thats what I was afraid of. Wish it would work though, the guy only wants $45.
Old Sep 29, 2007 | 07:43 AM
Add a bypass regulator after the filter and it'll work fine.
http://www.vulcanperformance.com/ser...gulator/Detail
Old Sep 29, 2007 | 09:58 AM
MikeThomas's Avatar
Hmm, thats a simple solution!
Old Sep 29, 2007 | 10:05 AM
1stgen's Avatar
Would I need one that would allow fuel to return to the tank/return fuel line or would a normal Holley style regulator work?
Old Sep 29, 2007 | 03:25 PM
You want a bypass setup like I showed. Install it between the filter and the injection pump.
Old Sep 30, 2007 | 09:58 PM
1stgen's Avatar
Thanks Dave. i think I will try it. What is the max pressure I should run?
Old Oct 1, 2007 | 04:32 PM
Set it for 15 psi. That's plenty for your truck and won't hurt the front pump seal.
PapeCAT
Dec 9, 2017 03:23 PM
GIT-R-DONE
Aug 24, 2011 10:27 PM
BurrisWill
May 29, 2009 12:58 AM
goodtyms
Apr 25, 2006 06:52 PM
CTD99
13
Aug 23, 2005 10:55 PM
