Piston lift pump upgrade help
#31
Is there a fuel line going from the lift pump to the injection pump. Can their just be a solid line going from one to the other bc I don’t need a fuel heater it don’t get cold down here
#32
If a previous owner took off the fuel filter and pump and you want to go back to stock then you need all the parts.
Edwin
garrettp62 (11-02-2018)
#33
Not sure what you're asking. There is a Solid line running from the lift pump on the side of the engine which goes to the cylinder head above the fuel filter/heater. There is a threaded tube which goes through the fuel heater that is sandwiched between the fuel filter and the head. There is another 2 piece line which goes from the fuel filter to the VE pump. You NEED the fuel filter but there is a shorter tube you can get to eliminate the fuel heater.
Edwin
Edwin
#34
i have an electric fuel pump coming from the fuel cell with a filter on it and he just by passed the on block fuel filter the lift pump and fuel heater so i dont need a filter bc it has one or heaterbc it only gets to maybe 30 degrees down here but i was just wandering if i can go from lift pump to injection pump and if there's a line that's made for that
#35
