piston lift pump
Old Feb 16, 2007 | 05:26 PM
smoky beast's Avatar
piston lift pump
I am running a stock lift pump and plan on upgrading soon.Will a piston lift pump push enough fuel for my current setup with no further mods?
many thanks again
Smokin Okie
p.s. I updated my signature
Old Feb 16, 2007 | 05:54 PM
2stroke's Avatar
are u N/I?
Old Feb 16, 2007 | 05:58 PM
ppiggppenn's Avatar
my oem LP was pretty lame so I added an electric one along the frame rail with no adverse effects. Not sure what "are u N/I?" means 2stroke, ...do I need to know? ...lol
Old Feb 16, 2007 | 06:00 PM
The piston pump should be able to keep you up around 8 psi. If you really aren't adding more fuel you will be fine with the piston pump.
Old Feb 16, 2007 | 07:50 PM
Ace's Avatar
Ace
The piston pump rocks. Just got mine on today. Holds over double the psi at WOT - 7 now, vs. 3 with the stock pump. Highly recommended!
Old Feb 17, 2007 | 06:45 AM
Boatnik's Avatar
I agree with Ace. The piston lift pump is something Wannadiesel tried to get me to do a while back. I should have done it then. If you are running a fuel gauge you will need some way to control the pulses or the gauge will not last long. I use a petcock at the banjo bolt on the filter out let and throttle it down to a tolerable level.
Old Feb 17, 2007 | 11:54 AM
yes it is non intercooled, and I really appreciate the replies
many thanks
Smokin Okie
PapeCAT
Dec 9, 2017 03:23 PM
GIT-R-DONE
Aug 24, 2011 10:27 PM
BurrisWill
May 29, 2009 12:58 AM
vinny
Nov 20, 2005 06:58 PM
CTD99
13
Aug 23, 2005 10:55 PM
