pine needles in heater door
Old Apr 4, 2005 | 07:56 PM
DeanM's Avatar
Hi
I have had pine needles fall into the cowl near the windshield. My heater door doesn't close all the way so I don't get good heat now. What is the best way to clean them out? Take the cowl off or take the heater out?
Thanks
Dean
Old Apr 4, 2005 | 08:35 PM
FrdRdnk's Avatar
I'm not sure on our dodges but I had a chevy pickup and I would never encourage someone to pull a heater core. Well atleast not in 90* heat.
Old Apr 4, 2005 | 08:53 PM
Somebody posted a while back that they cut a hole in the heater box, cleaned it out, then screwed a sheet metal patch over it. Seems like the easiest solution if you aren't overly concerned with appearances.
Old Apr 4, 2005 | 09:52 PM
edwinsmith's Avatar
Had to replace the heater core in my 92 S-10. I had to unbolt the entire dashboard to get the cover off the heater. Not a fun job in any weather. Have you tried compressed air backwards?
Edwin
Old Apr 4, 2005 | 10:24 PM
59FORD's Avatar
cut down the pine tree
Old Apr 4, 2005 | 10:34 PM
edwinsmith's Avatar
Or maybe take off the cowl and hope a robin will get them out to build her nest.
Old Apr 5, 2005 | 06:18 PM
ChrisLib's Avatar
Is this what your talking about?
http://ramchargercentral.com/boards/...owtoshow;id=45
I did this on my 86 and it made a huge difference, found all sorts of nasty stuff in there. When the time permits i`ll be doing the CTD also.
Old Apr 6, 2005 | 04:43 PM
uncleroty's Avatar
I did the cut out thing, and maybe was the guy who posted on it, I can't remember. A mouse nest was in there. It fixed up the problem. Just be careful where you're cutting.
I've done it on my 77 gasser as well (leaves), or more accurately the resulting fire did it. I just duct taped the hole shut after I put out the fire and cleaned it out.
This shows that it's a great idea to get that stuff out of there. There is a resistor in there that gets hot enough to start a fire.
Old Apr 7, 2005 | 03:58 PM
FrdRdnk's Avatar
Fourwheeler magazine recently ran a tech article on dodges and cutting the heater box open was something they suggested to prevent having a fire.
Old Apr 7, 2005 | 05:24 PM
Blowndodge's Avatar
could dirt in there cause my AC not to be as cold. Also, why would you want a bypass valve for the heater as described in that link?
brad
Old Apr 7, 2005 | 05:59 PM
ChrisLib's Avatar
brad
The stock heater valve only shuts off hot coolant to one of the heater hoses, this allows the heat from the engine to "creep" into the heater core, thus reducing the efficiency of the a/c. The bypass coolant valve show in that article loops the coolant flow and completely closes the heater core off from the coolant. I havent tried it myself but I hear tell that it makes a noticable improvement in the coolness of the a/c.
Old Apr 8, 2005 | 09:03 PM
DeanM's Avatar
A little update. I took the cowl off and I took out a some pine needles but couldn't get to the air flapper to clean it out.
Dean
Dale_K
Jun 2, 2008 09:27 AM
BearKiller
Nov 13, 2007 05:33 AM
RJ285
Jul 18, 2007 09:21 PM
Dave88LX
Jul 12, 2005 09:42 AM
Cummnzpowr
Aug 7, 2004 08:49 AM
