phenolic brake caliper pistons????
Old Feb 27, 2016 | 08:06 PM
1993w350's Avatar
I need to put a pair of calipers on my w350 tomorrow but the parts store list either phenolic "plastic" or metal piston material. Ive never even heard of plastic on a brake caliper so what should i buy?
Old Feb 27, 2016 | 11:55 PM
Unless this is some new product the aftermarket is trying...I have never heard of a plastic type caliper piston for our trucks. I would want to go with the steel/metal piston personally.
Old Feb 28, 2016 | 06:52 AM
jerseybud's Avatar
Both calipers that I've ever had seize had metal pistons. My truck sits in the winter so i purposely pick phenolic calipers.
Theres pros and cons to both, which is detailed in a couple places on the www.
Old Feb 28, 2016 | 11:46 AM
How often do you flush your brake fluid? If the truck sits a lot, then I would flush the complete system every year, only takes me about 30 min, by myself. I started flushing my brake fluid every 2 years max, about 10+ years ago...I have not had a single wheel cylinder, or brake caliper fail on me in all that time.
Old Feb 28, 2016 | 04:28 PM
jerseybud's Avatar
first was a aftermarket caliper on a 83 w150- brake fluid never changed, just bled.
second was a 88 w100- brake fluid changed every other year or so. Actually 2 froze up on this truck- one was a napa, one was a fly by night thing from rhode island that was pretty sketchy. Other problem is it sat for 3-6 months at a time during winter.
I've had good luck with napa eclipse calipers so far.
Old Mar 1, 2016 | 06:54 PM
samiam4's Avatar
Chrysler had a tsb to change phenolic to metal on customer experiencING sticky calipers.
Use Dot 4 fluid, change every 2 years.. all problems will disappear.
M
DodgeRam24V
13
Oct 27, 2011 11:28 PM
RollinCoalSmoke
May 29, 2009 09:20 PM
Hercules
Aug 17, 2008 09:00 PM
skynyrd
Jan 10, 2008 06:41 AM
ddestruel
May 10, 2005 12:17 AM
