performance!
Old Sep 28, 2009 | 06:33 PM
petrecca8's Avatar
performance!
ok i got a 92 dodge W250. and i was wondering what all i could do to up the horsepower on it. Im all ready plannin to put a new turbine housing on it because i have the 92 and it came wit that big 21 cm turbine housing. but what else coulld i do thats on the cheap side? im 17 and it used to be my dads truck and i want to make it nice but im on a limited budget anything will help thanks guys
Old Sep 28, 2009 | 06:36 PM
schamran's Avatar
you could just go with an hx-35 turbo if you have a 5-speed. You should fill out your signature so that the rest of us can tell what you got. Year, model, tranny, rear end, and whatever else you have done to it. That way we can give you advice based on what truck you have. auto/manual is the big one as far a performance goes though.
Old Sep 28, 2009 | 06:40 PM
petrecca8's Avatar
oh all right i got to figure out how to do the signature thing first but i got an auto tran its pretty much a brand new tran cause the other one went up on me. the new ones got like tripple the clutches and more valves or something like that im not to sure cause it wasnt my truck wen it was put in. i just know it is alot nicer than the old ones
Old Sep 28, 2009 | 07:25 PM
oilcan64's Avatar
welcome! im 17 too, get a set of gauges boost and pyro so you can mess with the pump- more experienced people will tell you all about that
genosgarage.com is a good place for gauges i like the autometer phantom 2 only they're really expensive- i've heard isspro makes a **** good gauge too
straight pipe it...you will love the sound!
Old Sep 28, 2009 | 07:50 PM
Take a look at the sticky. There's all sorts of free/cheap stuff you can do for more power in the performance post.
Old Sep 28, 2009 | 08:16 PM
RollinCoalSmoke's Avatar
oilcan64 you think he will get hooked on the performance stuff? petrecca8 welcome to the forum. As said above there is alot of free stuff you can do yourself. But there is a cost to it though-you will want more then more then more. You will find alot of good guys willing to help you out on here. Good luck on your ole truck.
Old Sep 28, 2009 | 08:54 PM
oilcan64's Avatar
[QUOTE=RollinCoalSmoke;2589987]oilcan64 you think he will get hooked on the performance stuff?
yep
im hooked! i think its a contagious disease
Old Sep 28, 2009 | 09:33 PM
82F100SWB's Avatar
Have you actually checked the turbo on your truck? Not all 92's have the lagmaster housing, you may have the 18.5. Yes, a smaller housing is still an upgrade, but, the stocker might not be that bad.
Old Sep 29, 2009 | 07:11 AM
If it is the 21cm with the automatic trans it will be doggy. Mine with the 21cm auto and GV od and 4:10s is a DOG. A convertor would help but that 6 to 900 bucks will be my 5sp conversion and make me as happy as a rat in cheese factory. My 5sp truck although a 93 with a 18.5cm housing will run a hole in the wind and with alot of 05/07 common railers.
Old Oct 1, 2009 | 03:00 PM
petrecca8's Avatar
im pretty sure it is the 21 cm housing but how could i double check that cause i know they went to the 18.5 in the 92.5 year. and im not sure if my truck was in that 92.5 year and all.
Old Oct 1, 2009 | 09:40 PM
93 12v's Avatar
Smile
Look on the backside of the housing between engine and it, at about 8 o'clock position looking at the backside. There's raised numbers right there to tell you what you have. That's where mine is. Pump mods are easy and pretty cheap. I got the 366 governor spring, and tweaked the pump a little and am satisfied with performance. I have the same tranny, but wouldn't mind either a shift kit or getrag, but I don't think you'll have tranny issues. As far as the pump, read up on it and follow the directions step by step and you'll be fine. Enjoy that truck! They don't/won't make 'em anymore!
Old Oct 2, 2009 | 12:57 PM
cedardiesel's Avatar
Welcome to the Site and I'm also 17 soon to be 18 but this is the site to stay hooked to. I have had so much help and learn so much more from this site as compared to any other site. I have since p-pumped my truck and now its under construction again for a B1 bomber over a B2 twin turbo setup and also southbend dual disk and NV4500 swap. That is amongst some things I have learn on this site. The easiest and cheapest mod for your truck is straight pipe and cranking the pump up and building your own cold air intake. Hope you enjoy the site and learn many new things
Old Oct 2, 2009 | 02:17 PM
Welcome to the site
Check the Sticky for free tweaks In the "performance" section.
To edit your signature Find "user cp" in the top left--
And on the left hand side column you'll see "edit signature" , Put in a bunch of details on your truck.
Old Oct 4, 2009 | 01:18 PM
92smokin blacky's Avatar
if your truck has the lagmaster 21cm housing, put a different turbo on it and turn up the pump and it will be a whole different truck! be sure to get gauges first though
ladyram
Mar 22, 2003 12:53 PM
Hired Gun
21
Mar 21, 2003 10:35 AM
Mexstan
Mar 16, 2003 09:34 PM
zeik
Mar 12, 2003 04:27 PM
