Parts to build an A518 to hold 350hp?
Old 07-02-2019, 01:15 PM
I'm pretty new to the diesel world and I have an experienced gentleman rebuilding my VE pump, injectors, and turbo. He tells me that it will create a lot of low end torque (and 350hp), I need to build up my transmission to hold the power. Exactly what do you guys recommend in parts/mods to get me there? I will not be pulling, this is just a daily/fun truck. Thanks in advance for whatever help can be offered.
Torque_Junkie is offline
Old 07-02-2019, 09:08 PM
j_martin's Avatar
A shift kit (valve body kit), good clutches and bands, and a few hard parts, I forget what, but it isn't much. If you're not pulling a load, you'd probably like the stock torque converter better than a low stall converter. On the other hand, a low stall converter taakes some of the strain off the transmission because of a lower converter ratio.
Oh, and I almost forgot. The weakest part is the stock flex plate. How do I know?
j_martin is offline
Old 07-02-2019, 09:14 PM
So how do I get said parts? And how do I know what parts are overkill and what aren't enough? (I'd rather go overkill, I just want to know where to spend more or less)
Old 07-03-2019, 07:26 PM
j_martin's Avatar
Transgo shift kit.
1835910 Platinum Series SFI 29.1 Rated Steel Flexplate $140 or so on eBay
I like the Goerend Torque Converter. I pull pretty heavy though.
There's a couple of build threads in the FAQ section of this forum.
j_martin is offline
Old 07-03-2019, 08:37 PM
Thanks, I did some more research on my own as well and from I can tell it wouldn't be a bad idea to go with billet servos and accumulator and of course the flex plate and shift kit. I'll have to see how it is with the stock converter. Thanks guys for the info, and to anyone wondering if this is enough for your build I'll continue to update this thread continually.
nonrev (07-04-2019)
Old 07-05-2019, 06:23 AM
j_martin's Avatar
With the stock TC, you'll be able to burn the tires off. With a low stall converter, not so much, but it'll drive more like a truck.
j_martin is offline
Mopar1973
01-21-2012 02:54 PM
06dually
130
09-17-2008 10:00 AM
dodgeguy71
04-30-2006 09:29 AM
diesel_kid
0
07-11-2005 11:18 AM
CTDwannaB
0
04-07-2005 09:29 PM
Quick Reply: Parts to build an A518 to hold 350hp?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
