P-pump Conversion
Old Feb 25, 2009 | 09:37 PM
cedardiesel's Avatar
P-pump Conversion
What is needed to convert to P7100 pump and what is the approx. cost for parts. I think my IP is on its way out so figure I might just go to P-pump
Old Feb 25, 2009 | 10:10 PM
peobryant's Avatar
9 times out of 10 it is cheaper to just find a complete P-Pump engine to swap in, instead of finding all the separate parts. It's a lot easier too.
Old Feb 25, 2009 | 10:31 PM
Fastback66's Avatar
So it's not a simple bolt on swap? I was curious as well. Great thread.
Vinny
Old Feb 26, 2009 | 03:53 AM
95ram's Avatar
Vinny
If you have a p-pump motor it is.
Old Feb 26, 2009 | 08:23 AM
sooty's Avatar
pppp pump
if you search the sigs closely youll see a few that have been modded, a lot of the 1st gen purists, including me, love their ve, one way to locate all of the parts, is to look for a blown motor, overheated or oil loss, youll need the timing assembly and cover, pump, lines, mounting, look closely at a motor to see all the associated parts for installation, anything missing? $$$$$ dealer, so, whats wrong with your pump?
Old Feb 26, 2009 | 12:47 PM
Well I think it is just showing its age finally after 320,000 miles cause if you read my other thread it is stumbling under heavy acceleration and at a steady throttle in sounds like it is running on all injectors the will the sound like it running of 3 or 4 then also just have lost some power also
Old Feb 26, 2009 | 02:15 PM
peobryant's Avatar
Vinny
Far from a bolt on swap. If you want to do it, there are quite a few threads with info about it, and a few that actually detail the swap. But like I said before, and as others tht have done the swap will say, it is a lot easier to just find a 2nd gen 12 Vlave engine and swap in.
Cedardiesel, I wouldn't count the VE out yet. What have you done so far to try to take care of the problem? We may have something else you can try.
Old Feb 26, 2009 | 06:07 PM
Well I have replaced the Lift Pump and also made sure no air is getting in the system. What else could it be?
jimbo486
May 8, 2016 06:07 PM
6 2 Carl
Nov 27, 2010 09:55 AM
wcialrlter
Apr 17, 2008 05:51 PM
Jason Starnes
Aug 9, 2003 08:53 AM
Agades
Jun 23, 2003 04:30 PM
