Oil Pan Gasket Help Please!
Of course drain the oil.
I would maybe power-wash everything under there BEFORE draining the oil.
I would not try cleaning as you will either damage the old gasket or possibly leave cleaner residue that might be detrimental to the #2 sealer.
If the old gasket breaks or tears a bit, just put the gasket back together and be a bit more generous with the sealer in that area.
The sealer will squish into any splits or tears.
If anyone spends a day or two getting this accomplished and it does not cure the leak, please don't tar and feather me.
As it reads on your tombstone:
Here Lies Bear Killer
Found Permatexed to a tree
and covered in Texas Prairie Chicken feathers
by an angry cummins owner.
Just kidding...
Jim
I wanna say the 11mm was a little too big which is right if their 10mm but I know I tried a 10mm too and it was too tight. Im thinking the paint layer is too thick. I'll have to check and maybe just tap the socket on. Thanks for the info!
bostongsx
Sep 25, 2006 11:25 PM
Common
Aug 24, 2006 06:31 PM
Diesel-Dan
May 26, 2004 04:42 PM
