Oil centrifuges
Oil centrifuges
Is anyone using one on there truck. I see that diesel power has a wright up on putting a Dieselcraft unit on a 7.3 I see that this unit has a small air pump to push the oil out of the unit [ DP states that this pump spins the centrifuge witch is wrong if that little air pump can spin the centrifuge at all I would be surprised] what spins them is the engine oil pressure . I was looking at the Spinner II units as I have some history with then. And the Spinner II units don't use the air pump to push the oil out of the centrifuge. I don't think you need a air pump if you have a good oil drain back to the oil pan. Ken
I've been running a centrifuge on my 05' Duramax for about 20k miles now, and it works great. There must be something wrong with the truck they ran it on in diesel power to get that much gunk in 1500 miles. I clean mine out every couple thousand and there is maybe 1/16" of thick gunk on the sides. Kind of like thick cold paint. Nothing like what the diesel power article shows. I am curious to see there full writeup on the centrifuge thats supposed to be in the aug issue. I did a post on this site as well as the duramax sites on how I built my own kit for $150. It may help give you some ideas and options as far as price goes.
I was under the impression that oil centrifuges were a bad thing. I think it was Mack(i'll have to look that up) that tried it years ago. There thought was it would centrifuge out all the soot and crap. But it ended up centrifuging out all the additives that make oil work well, and took all that out and the engines ended up needing overhauls sooner. They dont use them any more.
I could do their coolant filter a lot cheaper. And the filter I would use can be ordered by any parts store worth a snot and have additives for the coolant to keep it fresh.
Just about every industrial diesel in a stationary, marine, or even commercial trucking/ agricultural setting have a centrifuge of some sort. This isn't some new oggity boogity voodoo snake oil that just came out last year!
I've even worked on with a Cummins C series that was an emergency generator set that had one.
Dzl_damon is right. ^^^ I don't know why Mack stopped installing them, probably so they could sell more parts. Because the centrifuge made things run better for longer, it wasn't so good for buisness. Just about every owner-operated Pete, K Whopper etc has one. Why? Because they not only work, they do a great job of cleaning your oil! I think powertripls is going to see a return on his one in... ohh, 3 oil changes?
Last edited by KD93; 06-02-2010 at 07:04 AM. Reason: Spelling/grammer. Bad English!
Sounds like a load to me .
I could be wrong, ive been wrong before.
Roughstock, a centrifuge is an additional filter. All the engines Dzl_damon is talking about have regular spin-on filters too. A centrifuge cleans the oil down to, depending on the type, somewhere around 0.5 - 2 microns. Obviously it's a type of bypass filter with that sort of filtering, as opposed to the full flow of a spin-on type. Hope this helps!
oil centrifuges
i would like to know the size of the hole in the nozzle of the spinnerII 25 and the dieselcraft 020 either in mm. or inches if anyone knows. i think they are both 0.9gpm at 60psi. thanks
GLHS, I think pwrtripls1 has a thread on his one, but if not I'd PM him. And I think Diesel Power did an article on putting one on a Ford 7.3l, so that article should be on their website. Dunno if that particular one would work for us, but I don't see why not.
GlennRMK
05-24-2007 10:46 PM
