OD button replace
OD button replace
Ok. I've been thru 2 factory overdrive buttons now and looking to replace it with A toggle. Has anyone done this and have A wiring diagram of how I could wire it?
I need a new one as well. Right now I am using the cargo light switch plugged into the OD plug but you gotta push the button twice to engage or disengage it. I need to get a 2nd gen shifter with the button in the end but i believe a toggle would work
I did the 2nd gen shifter on 2 of my trucks, love it and works like a charm. It is an easy 2 wire hook up,
18ga Black = One side of the OD switch
20ga Orange w/white tracer = The other side of the OD switch.
(the other wire(s) are for the light.)
I spliced it in line so I can use either switch and retain the OD light on the original button.
k im new to this site havent figured out how to post. lol im a mechanic by trade. built 1000hp drag trucks with small blocks ect... however i got my 1st diesel its a 92 2wd with 600k still going strong. i need to know if there is a switch on the side of the trans for od? my trans engages in and out of od if im not going over 70mph but all the other gears hit nice and hard . HELP!!!
Just what is shown on the bottom of the above diagram. You probably need to start by adjusting / testing the TPS (Throttle Position Sensor).
http://www.pdrdiesel.com/oldsite/Tech1GTPS.htm
Lots of info in the sticky.
Here is a good video for bumping the timing
https://www.dieseltruckresource.com/...ml#post2596889
And for more adjustments
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
Ok. I hooked up A toggle switch to the OD and still have to double click it like U do using the cargo light button. I don't like it. Does anyone still make the stock switch?
TheOutdoorsman
05-17-2013 07:22 AM
Tedonlin150
02-04-2010 11:37 AM
can17
11-10-2008 02:53 PM
