O-Ringed head?
O-Ringed head?
Just picked up the march edition of diesel power, got lookin through the project rust bucket pages, it says they had the head shipped out to be O-ringed... stupid question but what does that mean and how is it done?
The head (and or sometimes the block) get a groove machined around each cylinder. A wire (usually copper) is put in the groove, then when the heads are torqued on the wire gets smashed and makes a very positive seal. This is generally recommended on our truck at pressures about 40 psi.
To expound on what Mark said:
O-rings do not necessarily get smashed, rather it gives an additional pinch point to the headgaskets fire ring, or the metal part that goes around each cylinder. Copper and stainless steel are 2 popular ones.
Fire-ringing is the process of of cutting a groove in the block like an O-ring setup. 2 pinch points mean even more holding pressure. However, these sometimes loosen up and are used mostly for competition who take the head off frequently.
Here's two pictures of what they look like, one on a 12 valve head, the other on a 24 valve head.
This is how I cut them in, a groove is cut so that it is centered on the stock fire ring. The width and depth depend on the diameter of the wire used, I use .050" wire and aim for a .010" to .012" protrusion.
wallawalla
Sep 12, 2007 11:31 AM
storx
44
Sep 30, 2005 03:36 PM
