Noodle Frame
Where's it cracking? Ramchargers often came with a steering box brace that mounts to the inside of the frame rail with an arm that bolts to the front cross-member. I picked up one of those for my crew project. RamchargerCentral.Com is a good place for you to look if you're wheeling your truck and need to do some heavy duty reinforcement.
Good advice, thanks. It cracks on both front framerails but especially around the steering box. I made an extra thick back brace for the steering box, and gusseted the left framerail to the cross member (which I welded up). I think I broke it again when I tomahawked off a viscious wheelstand at the strip last summer!
Just kidding (about the wheelstand). I think my 120 MIG has met it's match with my frame. I need to empty the change jar and find a 240.
Ive bent tests from 3/8 plate and passed with a lincoln 120. should be enough for these frames. are you getting any preheat before welding? I don't want to question your technique, but mayhaps the weld was cold. What I plan on doing(probally wont ever happen) is find the same frame as mine at a scrap yard, cut it up, and box it up old toyota style.
I just need to box whole thing!!!!
I had one crack in the crumple zone which is in the dip on the top part of the channel section near the front of the steering box. The older Dodges had a vertical reinforcement in this same area. Another re-engineered Dodge failure to meet government safety specs.
roxxx
Nov 19, 2021 03:07 PM
gts95
Aug 27, 2007 10:13 AM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
