No tail lights license plate lights or brake lights when key is on.
Just like the title says when the key is on and head light switch is pulled I have no lights at all in the rear. No running lights brake lights or license plate lights. But if I turn the key off everything comes on. The issue is only in the rear and I haven’t the slightest idea why it’s happeneing
Update
Change the switch and it didn’t fix the problem. Also checked power at all fuses both key on and key off and everything has power at the fuse panel.
First thing I'd check is the grounds at the lights. With the switch off, the turn signals and brake lights will return through the tail and clearance lamps. With the switch on, the return would be to 12V, thus nothing will work.
The other thought that crossed my mind is a bootleggers rear lamp cutout relay.
nonrev (05-11-2019)
Fixed!
The following 2 users liked this post by Gizmo52:
nonrev (05-11-2019),
nothingbutdarts (05-11-2019)
DIESELWRKS
02-27-2015 09:30 PM
95black2615
01-07-2006 02:32 PM
stevenknapp
02-25-2004 11:58 PM
