No resistance on the lift pump lever.
Old Jun 16, 2008 | 01:14 AM
Trooperthorn's Avatar
When I work the priming lever on my lift pump on my 92 donor engine, there is very little resistance. Is this normal if there is no fuel in the system? I assume it is just working the diaphragm but it seems like I should feel some resistance.
To repeat. There is no fuel in the lines.
Old Jun 16, 2008 | 01:17 AM
Alwaysworking's Avatar
alwaysonDTR
fuel makes a difference and rotation of the engine too, put fuel in it and then try it or turn the engine over a little then try it
Old Jun 16, 2008 | 01:53 AM
Thanks, I was just reading BC's sticky on the piston pump. Since the side of my engine is wide open, I may do the conversion. I have heard that the diaphragm will not hold up to my homebrew fuel. I need to call around on the parts.
Old Jun 16, 2008 | 09:46 AM
dodgezilla04's Avatar
the pump lever may be up on the cam lobe. rotate the engine 90* and try again.
PupleDiesel
May 4, 2009 02:40 PM
D.Wiggs
Apr 22, 2007 08:23 AM
vzdude
Jan 30, 2007 09:37 PM
george7941
Feb 8, 2006 08:22 AM
HOHN
Oct 18, 2004 11:48 PM
