No power at Blue wire at od solenoid
In the process of chasing a speedo, c.c., od problem
Tried to ground overdrive solenoid but didn't work
Tested for 12volts on "blue" wire at overdrive solenoid and got nothing with key on tried all shifter position
Got continuity through it to pcm plug with battery disconnected but no 12V
Anyone
Anyone
That blue wire gets its power from the ignition switch. It power multiple things. A/c cycling switch, fuel heater, Fuel shot off solenoid. There is a black plug and a grey plug at the back of the cyl head kind of above the lift pump. That blue wire is in the black plug. 1 of the corner wires, its a rectangle plug. Check to see if power is at both sides of that plug. Check continuity to the pcm only checks the ground side. The pcm grounds the solenoid for OD. The orange and light green wire for the ground goes through the grey plug to the pcm.
ok so i checked the black plug at Tron suggested
12.06v on either side but no power at solenoid plug what now?
So the power wire doesn't hook to the pcm at all?
i can find continuity through the solenoid plug and the pcm plug
Could any of this come from a bad or misprogrammed pcm (mine was just replaced with a reman. due to charging issues)
shorthair
15
Apr 30, 2009 08:42 AM
barngal6
Jan 6, 2009 06:30 PM
RenegadeT
Nov 2, 2006 12:06 PM
TPilaske
16
Nov 22, 2002 08:15 PM
